I've got Avidemux and it's pretty much suited to my needs; I've converted a few old AVIs to MPEG-2 and TS files easily.
However, one thing I'm trying to learn is editing the aspect ratio of certain frames - I've got a programme taped from DVB,
but the adverts are 16:9, the programme is 4:3, how would I edit a frame to a certain aspect ratio?
I can cut out commercials fairly easily, may as well learn another new skill as I learn this program!
Yes, I know it's painstaking work, but I'm doing this so I can learn... aspect ratio editing isn't a common thing is it?
Basically what I'm trying to do... edit aspect ratios in Avidemux, which I haven't found a feature in my version (version 2.5).
Any advice is appreciated, thanks.
The aspect ratio is set in the compression codec's settings. I don't think AviDemux will allow you to set different aspect ratios for different parts of the video. You may have to break it up into sections and join them later.
Note that with some codecs you flag the display aspect ratio (shape of the displayed frame), some you flag the pixel aspect ratio (aka sample aspect ratio), the shape of individual pixels. The general equation:
DAR = SAR * PAR
DAR = display aspect ratio
SAR = frame size
PAR = pixel aspect ratio
For example:
DAR = SAR * PAR
DAR = 720:480 * 8:9
DAR = 720/480 * 8/9
DAR = 720 * 8 / 480 / 9
DAR = 1.333... = 4:3Last edited by jagabo; 20th Jan 2012 at 21:14.
avidemux - x264/mkv with chapters? + aspect ratio question.
By simon_h in forum DVD RippingReplies: 2Last Post: 22nd Nov 2011, 15:13 -
Avidemux: MP4 aspect ratio
By higgins327 in forum Video ConversionReplies: 0Last Post: 31st Mar 2011, 03:03 -
Can you change Aspect Ratio in Avidemux without reencoding?
By tokintmash in forum EditingReplies: 3Last Post: 13th Aug 2009, 09:05 -
[Avidemux] Aspect Ratio vs Playback
By Shadarr in forum EditingReplies: 9Last Post: 12th Aug 2009, 09:54 -
aspect ratio change and Avidemux
By Ogilvy in forum LinuxReplies: 0Last Post: 30th Apr 2008, 09:44
